1 - 1 of 1 Posts
Need help restoring a 68 Z28. Original engine had a wire clip on the top right bell housing to engine block bolt which secured the starter solenoid harness above the started. Issue is with the engine installed the clip has less than 1/8" to the firewall. Can't find any reference to the solenoid wire harness in the assembly manual. I don't remember this tight clearance when I disassembled. I have installed new motor. mounts.
thanks Joe
1 - 1 of 1 Posts
