I'm rebuilding my '68'vert..
All new wiring, crate engine, MSD-HEI, hi-torque mini-starter, etc..
I bought the American Autowire kit and everything looks good so far, but....
I could use a few opinions on this..
I found a nice diagram in the tech area of what it should look like.
My AAW looks like this, 4 wires, which also matches my '68-AIM.
Am I crazy, or do I need to snip the loop terminal off the purple wire,
solder on a special water-proof spade connector ??? (where the hell do I get this? see starter pic)
which will plug in below the battery cable.
..and just cut-off and tape up the yellow wire, (not used)..?
does this look right to you guys?
thoughts? comments?
- Red battery cable (2 gauge wire, not show)
- "S" wire (purple-starter switch)
- "I" wire (yellow-ignition coil)
- Oil pressure sensor (push boot-spade)
thoughts? comments?
