1 - 17 of 17 Posts
The starter on my 69 temperally died yesterday after I drove 25 minutes. I have headers on the car and I know they cook starters. When the starter cooled down it starts fine. I have driven the car longer and this has never happened before. Do I have to find a way to keep it cooler,or does it need to be rebuilt or both? Thanks Cary
69 Z-28 R/S:Daytona Yellow,Blk Vinyl Top,X33,DZ302,M21,4.10 Posi,Dlx interior,8k tach,console and guages,wood wheel and dash,ZL2 ducted hood,endura bumper,30300 miles.
Cary,
You can put a F--d starter relay on it and it will fix this problem.
Mount the relay and take the purple wire from your starter to the small terminal on new relay marked "S". Then run 10 ga. wire from hot on starter solonoid to one side of the new relay, then run a 10 ga. wire from the other side of relay to your starter to where you removed the purple wire.
Be sure you have a nut for "S" term on the new relay before you leave the parts store because they normally don't come with the relay.
Larry
The relay recomendation should solve your problem but if you keep having it, you may want to verify for worn out starter bushings.
i added the f--d starter relay to my big block and haven't had any troubles. you know, this could be the "better idea", that they always claim they have.
bruce
Thanks for the advise. So the solonoid is the problem? My car is bone stock so mounting a F-RD part on my car is not an option. The soloniod doesn't click or anything,when I turn the key? Any other ideas?
I don't know if F**D had they better idea when they designed the assist relay. I think they did it to turn over those high compression motors trying to keep up with the bowties!
Mark
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
Classic Industries also makes a solenoid heat shield for $14 plus $8 for a retaining nut. Page 488 catalog c2000.
I used it when I rebuilt my motor and have had no problems.
$8 retaining nut, sounds like a government contract
68 RS, Ash Gold,pwr windows,Hounds tooth
It's a "special" retaining nut...does that help?
69 z28 (clone) w/502/502
69 Yenko
was just messing around. I know some parts aren't cheap
The reason the starter don't click is because it is hot and heat causes resistance, and to over come resistance one must up volts/amperage.
If the *#@^ solonoid is not an option then try a new starter, and the shield, and the cheap nut. but being it's stock the starter only will likely fix it.
Larry
the most common cause for your problem is running a cheap rebuilt starter propably for 350 aplication.if you have a BB insist on a bb aplication,i use 75 chevy truck/454
Make shure the safety switch on the steering column is not going bad, I'd replace it and see if it helps.
Auto trans - it's a neutral safety switch.
Manual trans - it won't allow the engine to start unless it's in reverse.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
We may be troubleshooting the same problem.
Listen to Dave and see my 89 Camaro Starting Problem posting. I will let you know by Friday 11/03/00 or sooner if the neutral safety switch did not solve my problem.
Mack
How many cold cranking amps does your battery have? I had the same starter problem years ago. The solution - I went with a battery with a higher cca rating. I went with a 1000 cca battery, but anything with over 800 cold cranking amps should do the trick.
Discussion Starter #17
Thanks for the advise! I know my problem is heat related because when the starter cools down it starts and cranks fine. I'm going to try the solenoid heat sheild and special nut. I think I'll have the starter rebuilt and replace the solenoid just to be safe. Cary
69 Z-28 R/S:Daytona Yellow, Blk Vinyl Top, X33, DZ302, M21, 4.10 Posi, Dlx interior, 8k tach, console and guages, wood wheel and dash, ZL2 ducted hood, endura bumper.
1 - 17 of 17 Posts
