1 - 12 of 12 Posts
Hello. I'm looking to attempt to remove the pump and steering box from 69 camaro. I'm fairly handy but don't really have a full mechanics tool garage. I'm looking for what wrenches and tool sizes I'll need to complete this job. I'd like to gather up all the appropriate equipment before I begin. Any advice is appreciated. I've watched some videos and it doesn't seem all that difficult. Is there a way to find out this tool info? Thank u in advance.
Jeff
basic tools is all you need, 1/2, 9/16, 5/8 maybe 11/16 in open and box end wrenches along with the same for sockets. you will also need a long and short extension with a ratchet.
3/8 or 1/2 drive would be your choice
if you have little to no tools I would advise getting a small tool set if you plan on working on your car
check harbor freight or sears for their starter sets. if your pockets are deep then you can go snap on matco etc.
You'll need a pitman arm remover. Van get a free loaner at most auto parts stores.
Good advice on tools, but be cautious buying the HF stuff, it's all Chinese junk. Years ago I bought a set of impact sockets from HF and many of them won't even fit over the bolt/nut as the manufacturing tolerances are like most Chinese stuff - poor. Can't go wrong with Craftsman (maybe they're made in China now too, but at least they're still true to size.) Steering box and PS pump R&R is easy, you'll have fun with it, good weekend project
The pitman arm nut I believe is 1 5/16" socket, not a standard size in a set, check with your buddies for that or buy and also a 3/4" drive ratchet helps to get it off, then on again to approx. specs then a 1/2" torque wrench to torque it on-140 lbs. Takes some effort.
Line wrenches, don't use a open ended wrench on the power steering line as most of the time you will round the nut off.
Sent from my SM-G920R4 using Tapatalk
Crow foot wrenches work great on PS hose fittings at steering box- If you have headers it gets a bit tight and may require the disconnection of rag joint and unbolting steering column to get a bit more room GL
Like John (Vega$69) recommended, you're not getting it off without the pitman arm puller (rent it).
some pitman arms are on so tight you have to heat it with a torch in addition to the puller. At that point take it to a shop and let them pull it.
HF makes crowsfoot sockets in flare wrench type, it grabs the hose end on more sides. you need that for the steering box hoses.
Harbor freight tools are a lot better than they used to be. I have a couple of sets of their metric/us impact sockets and they all fit correctly and have held up very well. I like Craftsman and for end wrenches (Proto Challenger is much better) and sockets but the HF stuff will work for low use/economy. The HF regular sockets will break sooner than a Craftsman but Craftsman is not top notch either. HF makes a telescoping ratchet in 3/8" drive and 1/2" drive that gives you extra leverage when you need it. I use mine for breaking loose lug nuts.
1 - 12 of 12 Posts
