A couple of years ago I changed out my manual steering to power steering on my 69 Camaro with a quick ratio unit. The seal in the new unit has begun to leak around the shaft that goes to the rag joint. My question is should I just take out the box and replace the seal or change the unit to a AGR 292117 unit. Is the Agr unit that much better than the quick ratio? The unit that I have now seems to work ok but does have a little wondering. But I do have the front lowered by 2" with lowering springs. Didn't know if I need to change to 2" drop spindes to fix this problem. I am also running low profile tires so that might bo some of the wondering. thanks
Just say "no", to drop spindles... You don't need them. How is your front end alignment ?
That may be all you need.
That sure would be easier than taking the complete box off. I will have to look to make sure what kind of box I have and get a seal for it. thanks
The part with the input seal can be removed if you loosen the large nut, then unscrew it. The seal is held in place with a snap ring. Shaft sizes varied over the years so get the right seal for your size shaft.
David
