1 - 16 of 16 Posts
Hi All,
I am preparing to install a complete power steering setup. New Box, pitman arm, idler arm, center link, tie rods inner and outer.
Any tips, cautions, advise? Or is it just that straight forward?
Guessing to count the turns on the box with a mark and then go half to center it for alignment of the pitman arm.
Any help is greatly appreciated.
Ron
It's a pretty straight forward swap. Spray the steering box bolts, pitman arm shaft/nut, idler arm bolts with some penetrating fluid a day or so in advance.
Take the center link and tie rods out as a unit, and use that as a template for the new setup. It will keep you very close to the original alignment to get you to the shop.
The pitman arm has a very large nut on it. You'll need a 1 5/16" socket. You'll probably need a pickle fork and a small sledge to pry some stuff off, it has been a while.
Hi,
New subframe, all new components, Nothing to remove. A good fresh start.
thanks!
Ron
Hi,
Does my centering scheme for the steering box rotations make sense. Don't want to install the pitman with incorrect clocking and have to beat it off to remove it.
Thanks!
Ron
Hi,
Thanks!
Ron
The pitman arm should be keyed. You can't really put it on wrong.
Edit, sorry, I see what you're saying. Yes, your idea makes sense. You should already know the approx. number of turns for the new box. Center it, and then intall with the correct key way.
Hi,
It is a 12.1 box. I assume it can be safely turned without being connected to a pump.
Would think the factory would center the box when they built it. But I want to be sure B4 I put the pitman on.
Thanks for your help. I'll let all know what I come up with.
Ron
1969 Camaro Restomod
Hi,
thanks!
Ron
Ron... I'd assume that if you're upgrading from manual to power steering, you're going to go with a "quick" ratio box rather than the standard power steering box? If you haven't bought the box yet, I think Bourgenson sells a complete kit with hoses, pump, PS box, and maybe the Idler but I'm not 100% sure about the idler. Available from Summit, Amazon, Jegs, etc..
Discussion Starter #9
Hi,
57 Vette, This is a complete new installation. I am not upgrading the entire vehicle is new.
I am putting a Flaming river FR1560 12.1 power steering gearbox in the car, I purchased all new Moog tie rods center link and idler pitman.
The PS pump is the one supplied on my Vintage Air front runner serpentine system. Kind of a mix and match deal. The car has new standard ration steering arms/spindles.
Now I am wondering about them, the 12.1 isn't really fast ratio is it? I had a choice between that and 16.1 which I thought was fast. Want to get this right. So any help is appreciated.
Build thread 'Finishing My 67 Coup' in Builds on this forum.
Thanks for any help!
Ron
Discussion Starter #10
Hi,
I guess I mislabeld the thread. Should be "New steering install"
Been gone a while.
sorry.
Ron
Hi,
Ron
12:1 is VERY FAST. If you have the fastest combo of steering linkage, it can be tough to drive. A stiff internal valve is manditory to use a box this fast on a first gen. Most 12:1 boxes have the stiff valving which keeps the steering from being too over-responsive.
16:1 is pretty slow.
14:1 is a good average ratio if you have the long pitman arm and short outer steering arms.
Some of the results depend on which of three lengths outer steering arms you have, and which of two lengths of pitman arms you use.
Read my info here: Camaro steering
Discussion Starter #12
Hello!
So the Flaming River 12.1 is a poor choice for a street cruiser.
I am so glad that you chimed in. What the heck box should I buy.
I have looked at the DSE, same price. FR has a 16.1, But from what you are saying, and you certainly would know.
A 14.1 is what I need.
I have looked and cannot seem to locate such a beast.
Please advise....
much thanks!
Ron
16:1 was used stock, 14:1 came out in 1978 or 79 for Z/28 only. The 12:1 was introduced around 1985 for the Z/28 and IROC Camaros. 14:1 is a nice & fairly quick ratio. As I said, A LOT depends on what length pitman arm and what length outer steering arm you have. I would use the long PS pitman arm Moog: K6582
The 12.7:1 is great for autocross and performance handling, but you don't want to use it with the short outer arms, AND long pitman arm. It's just too quick and the car will be hard to precisely control & make the car go exactly where you want, it's too easy to overcorrect. Its OK if you use the short pitman with short outers, or if you have the long outer arms you can then use the long Pitman arm. The 12.7:1 box with fastest linkage will be LESS than two turns lock to lock. Probably around 1 3/4 turns.
Discussion Starter #15
Hello Mr Pozzi,
I am so greatfull for some help from a truly knowledgeable expert. Gotten kinda lost in this steering thing. Will check my part numbers per your advice.
Thank you very much!
Ron
Hi,
Thanks, I found a 14.1. and its on it's way.
thank you very much!
Ron
Ron...
When you get it installed, post back here and update. I'm going from the original factory power steering box that was on my X44 car to a '96 Jeep Grand Cherokee box that I picked up locally. Should be an improvement, I'm using the existing Camaro arm with the JGC box. Got my fingers crossed LOL.
Mike
1 - 16 of 16 Posts
