is the steering wheel supposed to have a wobble when spinning?
i have a new remanufactured tilt steering column from ground up with a new comfort grip 3 spoke wheel.
my old column and wheel did the same thing.
i held the whole column up unlocked it with the key and spun it by hand. the hub and everything else spun true.
i just want to make real sure that this is ok or should i try to fix the wheel
thanks
So the column is true, and the wheel is not ?
I have a GM tilt column but an aftermarket wheel, no wobbles.
yes even my original column with aftermarket foam grip wheel wobbled
one day i will take the wheel off and put it on a level surface and put a level across it
