1 - 2 of 2 Posts
I have a '69 Z28 with the standard steering wheel which is black, and I'm planning on repainting it due to some work I did on the wheel. I've been told that an adhesion promoter needs to be applied first for the primer to stick, then a primer that's used for hard plastic applied, then paint it the desired color. Does anyone know if all of this sounds correct and if it does what type of paint should I use? Thanks, Donnie...
1 - 2 of 2 Posts
