1 - 2 of 2 Posts
My question is if I want my 327 motor to look stock can I put on original valve covers that has no holes in them. My 67rs camaro has a pcv on the drivers side valve cover and a hose from the air cleaner to the passenger side valve cover.
Banned
Only if your 327 engine has a block that has the draft tube hole back by the dizzy that they plugged w/ an adapter that had a hose attached to it that run's up to the bottom front of the carb. if it is a stock Q-Jet.
And then you also have to have a tall oil filler tube and breathable cap on the front of your intake..
pdq67
1 - 2 of 2 Posts
