Has anyone had to "center" a stock GM bell housing?
I checked mine and it is .009" from being in line with the crank. Centerforce has instructions with the clutch stating .005" max.
Is this common or am I just lucky?
joe
Seems like .009 ought to work on a street car. Have you tried to shove the bellhousing over and re-check?
Offset dowells are available to fix it.
David
David's Motorsports page
First Gen Suspension Page
No, I have not tried to move it...
Maybe I am doing this wrong, the .009 is the total difference in reading, if I use offset dowels I will need .0045 to center it perfect...
Does that mean it is off-center by .0045 which is within spec?
thanks,
Joe
