1 - 10 of 10 Posts
I just installed a 6AL syetem and my tac dosen't work properly. It will only read to 1200 rpm. I have switched from the coil to the tac output on the box with no sucess. Do i need to buy the Tac adapter????????
Not 100% on that, but if it worked before the MSD, most likely will need the adapter.
If your tachometer doesn't read correctly after installing an MSD, you may need a Tach Adapter.
On GM vehicles, first remove the tach filter. There are two MSD Tach Adapters.
Contact MSD Tech with the manufacturer of your tach and what you have installed on it to determine which Tach Adapter you will need.
I have an MSD 6AL and mine didn't need the adapter, even though I bought it ahead of time.... if you'd like, I'd sell you mine that I got from Year One here in Atlanta.
Thank's Dwight for the offer but I have already bought one, just havent hooked it up yet. You mentioned that u are running the same setup with no problems, may I ask how u have your tac hooked up??
I have a factory tach and the same MSD setup. All I did was run the wire from the coil to the MSD box and everything worked fine.
That's what I did also. I'm not sure why some would work and some wouldn't. Keep in mind that I purchased a GM Restoration Tach from Rick's, so I'm not sure if there's a mechanical difference between the originals and the newer Tachs. *Shrug*
which wire from coil and where did you hook it up to msd??? i have the 6al and pro billet distributor...
"I have a factory tach and the same MSD setup. All I did was run the wire from the coil to the MSD box and everything worked fine. "
Discussion Starter #9
I found out the problem was the tach. I had bought it off of e-bay, it was susposed to work??? I bought a oer and it's working fine. Thanks for the intrest in the post.
Is the OER tach one with the metal face, or are they still doing the plasic face with a sticker?
I bought a repro tach when they came out, and determined the quality to be unacceptable. I paid the $300+ for an orginal, which BTW, works fine with my Accel 300+ ignition box.
1 - 10 of 10 Posts
