1 - 8 of 8 Posts
Getting a real strange sound when I turn the car in a left direction....
Any suggestions on what to be looking for nothing is rubbing checked for wheel bearing and hub play and does not appear to be any....
Thanks Steve
couple of suggestions:
Exhaust pipe or muffler hitting driveshaft. Posi-traction device needs GM additive to gear oil.
I think it's in the brake mechanism. Maybe the caliper pins are binding or it's not centering on the rotor?
Checked clearances and they are good...just put the rear end back together and used limited slip gear oil and 4 oz of the GM additive....
Driving me nuts so I took it out again for another ride and the sound does drop off when I depress the brake pedal through the turn....next weekend I will pull the front brakes of and make sure the sliders aren't binding and they are centered on the rotor....
Possibly low on PS fluid? Had the same thing happen to our work truck.
Sounds to me like the rear brake area.
Can't be the ps. Was making the same noise with the 355 and old pump before we did the LS swap
Try changing the rear disc brake pads.
Discussion Starter #8
When I was working on the rear end this past week I reset the rear calipers for the E brake and there was absolutely no drag on rear brakes.
It is definitely coming from the front and I think its the passenger side but I will get it up in the air again to figure it out.
1 - 8 of 8 Posts
