Guys,
I was installing new header gaskets with ARP bolts this weekend. The heads are TrickFlow aluminum pieces. Was using my 1/4" rachet when I felt it break loose - I stripped the bolt hole in the head. What are my options to "fix" this?
Feeling pretty stupid at the moment....Marty
Marty
69 Camaro, 350, TrickFlow heads, T5, 3.73
Sometimes you can put a stud in the hole and catch a couple threads at the bottom of the hole. A stud will hold quite a bit like this. Otherwise you'll have to put a thread insert in the hole. Talk to a local auto machine shop and they'll have a thread in insert that you have to drill out the hole bigger, put the insert on a bolt, and just turn it in. Helicoil is the best, but expensive and harder to use, but it might be worth the trouble with these heads though.
Take a good look in the hole. Maybe you only pulled out one thread and can chase out the threads and put a bolt back in.
I'd like to add that anyone with aluminum heads make shure you are using long enough bolts or the bolts will tend to loosen and/or strip.
Of course, when using longer header bolts, make shure they don't bottom out.
I think some Big Block bolts are a bit longer.
I've found that helicoils on aluminum castings help keep bolts from coming loose.
The aluminum doesn't hold the bolts very well by itself.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
[This message has been edited by davidpozzi (edited 10-29-2000).]
I had to "heli coil" one of mine before. Not a big problem if you have a straight shot on that bolt. The back ones are a different story though.
Mark
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
That's why Edelbrock heads come stock with Helicoils in the header bolt holes. Also a good idea to use some anti-seize on the header bolts (should use it any time you thread a bolt into aluminum or into header bolt holes in either iron or aluminum heads).
JohnZ
'69 Z28 Fathom Green
