Gathering up all my 383 parts, going into a 1970 CE 010/020 block. Laid profiled crank in and mocked up one Compstar rod on piston to check rod /block clearance. Looks like Arp cap screw hits the outer lower cly area. How are you 383 guys handing the grinding. I was hoping to find about what is needed to lay a grinder stone to , but rotate the rod out of the way so I can get a good fit. Is that what everyone is doing? Anyone have an idea how much meat is in this corner just below pan rails. Seems to have more meat and no factory knotches when compared to earlier blocks. Rails are a good ways from bolts so I am ok there.
My other thought would be to mock up rods for each rod pair and do the same then move to next one. I intend to cover the area to keep grind shaving contained. This is a trail fit for everything and all will get a good bath before final assembly.
Jim? Anybody?
Jim? Anybody?
