Hello, I have a 400 bored 0.040 over to make a 408. I am now looking to upgrade the crankshaft from the stock 3.75" stroke to a 3.80" stroke. The crank I found is for use with 6.0" connecting rods, and it currently has stock 5.75" rods, which are being replaced as well. So with this block clear 6.0" rods and a 3.80" stroke? Otherwise, what are my other options? What would this bring my displacement to? Thank you.
***I just found a 4.0" stroke crank! What about this one?***
B.C. - Chevy408
[This message has been edited by Chevy408 (edited 04-28-2001).]
You're going to wind up with a really odd combination, and you'll need custom pistons made - for the money you'll have to spend, you'd be better off (IMO) to optimize the 408 you have now or build a stout 383 from scratch (good 4-bolt 350 blocks are available everywhere, with an enormous selection of "normal" parts to build them with, at reasonable prices).
JohnZ
'69 Z28 Fathom Green
BC (?)
The 3.800 stoke will give you a 414, not worth the hassle in my opinion. A more common deal is to use small journal rods and offset grind your 400 crank to get a 421. This will clear the stock block with some minor grinding and the parts are readily available.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1971 Chevelle "Heavy Chevy" original owner
1973 Z-28 ..one family car...Brother bought it new in 73
the 4'' crank with .040 over block will be 436 cubes.
