I just strip down my sub today and found some cracks around the spring opening also the lwr control arms. Do you guys think the sub damage is ok to repair? I am ok with replacing the lwr arms but would not have to spend the extra $$ but better safe then sorry. Let me know what you think.
I would V out the crack and lay out a good hot bead to get good penetration. Take your time and weld 1" at a time and it should be fine.
That is what I was think on both items but was not sure. what about the shock mount area, it look like it has been cut out.
