1 - 1 of 1 Posts
Hey guys, i know this has been talked about on numerous occasions, and i've used the search tool more times than i can count- but i was wondering, i bought some SFCs and an Energy Suspension kit, and everytime i tighten up the bolts, the bushings are not sitting center... and it's almost like they're not lined up and snapping in with one another. Is there something else i should be doing? I welded the second set of mounts (due to the typical rot) and the rears i left alone, because i didnt want to screw up the alignment too much. My front core support holes are still in great shape, but i did buy the plate kit to repair everything. With the rearmost holes not repaired (with a little rot) will this mess anything up, or shift the subframe at all? Thanks
1 - 1 of 1 Posts
