1 - 2 of 2 Posts
I have the 68 camaro convertible that is for sale, but after seeing crossrams 69 conv I am having second thoughts.
Does anyone out there have factory specification on body or frame alignment for the first gen convertibles? I just pick up some subframe rails and would like to install them using factory dimensions to align the body to the subframes.
The information on dimensions for the body to subframe are in the Fisher manual and the factory Assembly manulas.
If you install the subframe yourself use these as the preliminary settings then take the car to the best Frame and Alignment shop around (check with local body and fender guys for referals) to be rechecked and a Four Wheel Thrust Alignment performed on the car.
'68 Rag-top SS350/350 (on it's way to a 200-4R)
1 - 2 of 2 Posts
