For a change of pace, we've switched from working on our
'69's body (80%done) to the subframe. we'd like to completely disassemble it and rebuild it.
Pardon me if I name a part incorrectly, I'm no suspension expert and I haven't read the assembly manual yet.
We've removed the engine, tranny, crossmember, steering box, and shocks. I've rented the spring compressor and have read up again on the procedure
(I already replaced the front springs on my '68).
The subframe looks mostly original, the upper balljoints(?) still have rivets.
I've soaked all the bolts and nuts with penetrant.
When I tried to remove the swaybar bracket bolts, swaybar to lower control arm(?) bolts, engine mounting bolts, etc., they are either frozen or just spin.
Am I wasting time trying to get them out intact?
Should I just cut or burn them off to save time?
Any other tips would be very appreciated.
TIA,
TIA,
