i have a fresh 350 with a GK 288 cam, currently have an edlbrock carb (1406) with the RPM intake (7101). not really sure about that carb yet though, got it used from a friend (had 10,000 miles on it). it doesnt seem to work right, should i change it?
also , exhaust, i have dynomax headers, the muffler shop guy said i should put the flowmaster direct replacement muffler on it (the in front of the gas tank one) instead of 2 mufflers. suggestions??
I have the same intake combo as you do on a 350 crate, only with stock manifolds. I went with 2 1/4 exhaust with TWO magnaflows and twin tailpipes out the rear, I like the results, Maybe Two mufflers may be the way to go...just my .02 Mike
They do not hang too low, I have multi-leafs in the rear and the bottom of the mufflers hang about 1/2 inch lower than the bottom of the rear end, so far, not prob...Mike
