For my MPFI setup on my 69 502 RS/SS 6-spd, I need to run two 10-AN lines (feed and return). Because the underbody of the unibody dips down once it gets past the front frame rails, the lines will be the lowest part of the car, and that makes me nervous (as in ripping them apart on a speed bump or something!).
Besides running them through the interior (insane!) or through the trans tunnel (likely not NHRA legal), I don't think there's another option.
I had first planned on using electrical conduit piping, but that's only a little more protection. So, my next though was to get some U-shaped iron and run a channel under there for the lines to pass through. Unfortunately, the underbody is by no means straight, so it would be tough to do.
Another thought I had was that if I install sub-frame connectors later, maybe they sit lower and I could run the lines beside one of them?
Any advice is well appreciated... I'm trying to do everything better, stronger, and safer than the factory would have, and this is definately not an area I want to compromise on... don't want to get roasted to death!
Thanks,
Dave
Thanks,
Dave
