Ride tech or speed tech suspension? 69 camaro street car mostly a cruiser not track car at all. . Suggestions experiences good or bad with either street assault speedtech or the full ride tech setup?
I can't help you at this point as i'm still in the thinking process myself... but, wanted to tag along to see the replies. I'm pretty sure i'll be going with Ride tech's Complete Coil Over System for my '68 with Tru turn and muscle bar.Ride tech or speed tech suspension? 69 camaro street car mostly a cruiser not track car at all. . Suggestions experiences good or bad with either street assault speedtech or the full ride tech setup?
As a one time owner of a car with that setup I recommend you get a ride in a car equipped with that package before you plunk down your hard earned cash....I can't help you at this point as i'm still in the thinking process myself... but, wanted to tag along to see the replies. I'm pretty sure i'll be going with Ride tech's Complete Coil Over System for my '68 with Tru turn and muscle bar.
https://www.ridetech.com/products/suspension-packages/1967-1969-camaro-firebird-coilover-system/
And how would one go about getting a ride in a car equipped with that package?As a one time owner of a car with that setup I recommend you get a ride in a car equipped with that package before you plunk down your hard earned cash....
Don
Ok,, I see you suggested Speedtech.. thanksSpeedtech torque arm gives a better ride than Ridetech four link imho....
Don
Don
I totally agree torque are is better than 4 link.I can't help you at this point as i'm still in the thinking process myself... but, wanted to tag along to see the replies. I'm pretty sure i'll be going with Ride tech's Complete Coil Over System for my '68 with Tru turn and muscle bar.
Ridetech generally will give you a test ride at any Goodguys show etc. See if a member here is nearby with that setup.And how would one go about getting a ride in a car equipped with that package?
Or better yet,, Tell me about your experience with that package?
Exactly:wink2:Ride quality is very subjective.
Don
Don how much welding needs to be done on that setup? how is it attached to center of a 12 bolt?dhutton;1783085[CENTER said:[/CENTER]891]Speedtech torque arm gives a better ride than Ridetech four link imho....
Don
About the same as the Ridetech four link. Weld in the cradle and weld brackets to differential. Torque arm attachment bracket sandwiches between differential and rear cover. Forward mount uses rear subframe mounts.Don how much welding needs to be done on that setup? how is it attached to center of a 12 bolt?
which is easier in your opinion. I will likely be doing it in my garage with minimum toolsAbout the same as the Ridetech four link. Weld in the cradle and weld brackets to differential. Torque arm attachment bracket sandwiches between differential and rear cover. Forward mount uses rear subframe mounts.
Don
About the same. Certainly the difference is small enough for it not to be a factor in the decision.whitch is easier in your opinion. I will likely be doing it in my garage with minimum tools
X2 A buddy of mine just put Ridetech on his 69 with the help of a BFH. He was not happyYou don’t have to take a BFH to your trunk floor
Don
I would go with ATS AFX spindles. Allows you to use lower cost GM C6 brakes which offsets the cost.so I'm hearing speedtech ? is the speedtech road assault compatable with the tru turn and ridetech tall spindles ?
