Good day all-
Have a 68 convertible that started life as a 6cyl now has 350/350T non ac.
Am confident the front has 6cyl coils , and the rear does has multi leaf with traction bars.
It sits too high and floats a LOT on the front.
Looking to spend under 2k- with self install for a new
Currently the center of wheel hub to fender lip is 16inch in the rear and 1 in the front.
1- suggestions on what to purchase ?
2 - I listed the hotxhkis kit as it “seems” to hit my mark , however without a good starting point or photo reference of another car I’m hesitant to buy it - it advertises 2inch drop up front and 3inch rear drop.
3- am I missing something or is there more info needed to get some good opinions And advice from the veterans in the forums ?
4- if you have a 67-68 and have bought the Hotchkis kit or similar would you mind sharing the photo and tire OD?
Lastly - I drive this a lot in the spring/summer/fall - it’s not a garage Queen I would like to have better handling and less bounce and body roll!
Thanks !
Wheel Tire Car Sky Land vehicle
1968 RS, ZZ6
I installed a Hotchkis TVS Stage 2 with a 2" drop (part #80015-2). Rear is a 1.5 inch drop, 2 inch in the front. I installed 2 inch drop spindles with the kit after talking to Hotchkis. Rear tires are P255/60/R15 and fronts are P215/65/R15. I haven't had on the road that much yet but the few miles I put on it the handling ride was excellent. It feels tight and corners great and I am happy with the ride height.
Tire Wheel Car Vehicle Automotive tire
Wheel Tire Vehicle Car Hood
Tire Wheel Car Vehicle Hood
· Premium Member
this is when I had a 3” front and back Hotchkis drop leafs and springs.
17” torque thrust
Then with 18”
Tire Car Wheel Vehicle Vehicle registration plate
it worked fine, even autocrossed with this setup a handful of times before I tubbed it and went to a torque arm suspension.
Discussion Starter · #4 ·
thanks for sharing ! Car looks awesome !!
On the 80015-2 kit-
did you use the 2 inch lowering springs , and also add 2 inch lowering spindles ?
Also, can you let me know your front tire size and the measurement from the center hub to wheelwell lip ?
17” torque thrust
Then with 18”
· Premium Member
On the 80015-2 kit-
Do not use lowering spindles on your Camaro.
Front and back, I used 3” drop.
get 0.5” or 1” tall upper ball joints.
tall lower tie rods
3” drop front an back.
Good alignment with at least 1 deg. Neg camber
And 5+ caster.
Subframe connectors,
good tires.
Then
Go around corners real Fkn fast. I did.
