1 - 19 of 19 Posts
I am getting ready to order parts to do a complete rebuild of my front and rear suspension. I already have Hotchkis lowering springs for the front, and plan on buying lowering leafs for the rear. I plan on staying with rubber bushings for the rest of the vehicle.
My question is, what manufacturer/dealer sells the best quality replacement bushings? Do they offer a kit that does the entire vehicle?
Majority of the suspension on my car is original. Everytime I raise my car on jack stands, chunks of dry rubber fall to the ground...it's really bad.
In addition to upper and lower ball joints, pitman arm, tie rod ends, tie rod sleeves, and control arm bushings, are there any other pieces that I'll need?
I also think that all of the body bushings are in a similar condition. Maybe I should replace those while I'm at it...
Any help would be greatly appreciated!!
-James
-James
Why have you decided to go with rubber replacements?
I don't want to have a lot of money tied up in the components, and the roads near me are pure garbage. I just figured that it would be the most cost effective option for the "softest" ride... Is that not true?
I'm not completely against "upgrading" components, as long as the increase in price was worth the increase in performance. Know what I mean?
When I first decided that I was going to replace the suspension I had decided to go with SC&C tubular control arms, Howe tall ball joints, poly or delrim bushings, etc. but the cost isn't justifiable now...or so it seems.
I did a lot of comparison shopping when I did my 79 Z28 this past winter and would up ordering all steering and suspension parts from Rockauto.com I got all Moog parts so I'm satisfied with that. I also went with rubber on a-frame bushings since poly is getting a bad reputation with the autocross guys. I did replace the body bushings with poly but have since purchased a set of solids and will be taking the poly out. Unless you're going to race this car, I think rubber will serve you well. Good luck with this.
I used pst poly bushing kit for my 69 camaro and 74 nova front end.. I am very happy with the kit. I also put in kyb gas shocks. I put poly bushing on body and rear leaf springs and I am very happy.
2x on PST. I did my suspension over 10 years ago with a PST kit along with Hotchkis parts, still feels as solid today. I stuck with rubber body bushings with exception of the rear one which is the poly one that came with the Hotchkis SFC 's.
I'd suggest the both the delrin UCA/LCA bushings (you can reuse your current control arms, although the SC&C arms are pretty nice), the tall ball joints and quality shocks, with the balance of the front steering/suspension replaced as needed. The idea is to make the control arm pivot points as frictionless as possible, so the springs and shocks can do their jobs. If you get a lot of "stiction" on a big jolt to the front tires, the car will seem much rougher than it would with delrin control arm bushings.
The tall ball joints correct the camber curve for the front end and will improve handling even on the street, particularly if you go to modern, wider tires.
Discussion Starter #11
Go with solid body bushings, and let the suspension handle the "softness" of the ride.
I have heard that's the best way to go. Who sells the best solid body bushings? Do they sell them as a complete kit?
I have heard good things about Performance Suspension Technology as well. I am hesitant to go with the poly kit because I have heard bad reviews about it making the car too "stiff", and leading to annoying squeaks. Have you experienced any of those symptoms? Do they carry a complete rubber kit?
Thanks a lot for the input. I think the delrin control arm bushings would be a good idea. What supplier has the best quality delrin bushings? Do they sell a complete kit?
I already have Hotchkis lowering coil springs and Moog lower ball joints. I am also pricing out Hotchkis lowering leafs. Other than those things, I need everything else...
I really appreciate all of your help and guidance!
Are you wanting to keep the car basically stock or do you want to improve the handling of the car? If you want it stock I can't offer any help cause I don't do stock. However if you want to improve the handling and braking I would recommend you take a look at the 48 Hour Camaro built by RideTech. All bolt on components and the results are amazing.
http://www.ridetech.com/48hourcamaro/
Discussion Starter #14
I used Global West upper and lower Del-a-lum bushings and love them. I can move the control arms up and down with one finger, exactly how Mike describes "frictionless". They sell a nice kit.
Did you reuse the stock control arms? Or did you go aftermarket tubular?
Yes, I used the stock arms and dialed in 3.5° caster and -.5° camber. I also used GW's offset crosshaft.
I do plan to go with their upper control arms only in the future, they have 5° caster built in to them. Their lower arms are built to stock specs and I would only need them if I needed more tire clearance which I don't.
I bought GW Del-a-Lum bushings for the stock LCAs and they are nice. Using SPC adjustable UCAs with delrin bushings.
Were I to do it again I would use the DSE delrin LCA bushings - they have a steel shell (vs aluminum) and can be tack welded to the LCA should the bushing bore in the control arm be distorted. About the same cost as the GW. http://www.detroitspeed.com/1967-1969-F-Body-products/030201-lca-bushings.html
My subframe mounts are Speed Tech aluminum.
1 - 19 of 19 Posts
