I've lowered the front on my 68' about 2". From what I've read ideally the sway bar ends should be parallel to the ground when installed. If I do that there's about 1.5" between control arm and sway bar end. Not enough room. So how long are you making your end links. Pictures would be great.
Jesse
Cut mine down to 1 1/2". Car has 3" drop springs. Also cut down the bump stops some.
By the way...Welcome to Team Camaro!
Thanks for the link David and picture Red Rocker. I will be doing this in a couple days.
Jesse
