And new oil. Everything else should transfer, except for speedo cable, if the Muncie is 69 and newer.
My 68 Sag had driver side speedo drive. the 69 muncie I swapped had pass side speedo drive. I had to get a longer cable and make a new hole in the firewall for cable. Hole was near the pedal.
Other than that, it was a cakewalk. Adjust back-up light switch carefully. You will have to use a length of metal coat hanger verses the OE linkage rod to activate the switch.
I believe everybody is correct. The OE shifter will work, but as said, the shift rods and their little shift arms bolted onto the trans needs to be for a Muncie.
I did make a mistake about the speedo cable, you have a 67 Muncie, meaning the speedo cable is on the driver side, as is a 68. I apologize for the mis-guidance, but the metal coat hangar for the new back-up light switch linkage is correct.
