Conflicting information among the T56 swap posts or people are using words interchangeably causing some confusion.
I have a T56 LT1 that I changed the input shaft to the LS1 shaft. MCleod 8-207 adapter plate is on the way. I have the Lakewood housing and mechanical linkage from the previous Muncie M-21 4 speed that has been in it for a few years that can be reused.
I have read that the LS1 input shaft is a bit shorter than the Muncie input shaft. Can someone clarify which of the following should be used in the swap? All three have been mentioned in t56 swap threads in the forums which is causing the confusion.
A. Extended Pilot Bushing
B. Extended Pilot Bearing
C. Extended Throwout Bearing
C - does not seem likely as the TOB already in use has been working for years and has little impact due to the change in overall length of the input shaft.
...and what part number should be used?
Any help is appreciated. Thanks.
