1 - 8 of 8 Posts
The previous owner of my 69SS installed a Sun mini Tach. They didn't connect the wire to illuminate the tach. Just stuffed it up under the dash. I think I'm going to splice it onto my speedometer light wiring so that it can dim. Want to make sure that the white/grey wire coming of the bulb socket is the hot and the black is the ground. Does that sound right to anybody?:confused:
Also, the power wire is wrapped around the end of a fuse and plugged into the FRONT of the fuse box. Looks really, really rigged. any suggestions?
I can see the grey wire but can't get to it to splice onto it.(I need my knowledge of what to do and my 5-yr olds arms and hands). From looking at a wiring diagram can I splice onto the dark green wire coming off the light switch? I think that leads to the instrument panel lighting but the diagram shows there might be a fuse.
Any ideas are extremely welcome
1 - 8 of 8 Posts
