1 - 12 of 12 Posts
Hi,
I've recently purchased my first muscle car: 67Camaro RS Conv.
I'm having some electrical problems, but first I need to know the basics.
Are the park, brake, and blinker all on the outside individual light? I only have one bulb for each outside lens, and no bulbs for the inside lens. I hope that makes sense. Any help??
Thanks,
Enrique
Enrique -
I did a search because I'm not 100% certain, but I couldn't confirm so I'll just tell you what I think and someone will correct me if I am wrong.
On a base car, with a red lens on the outside and a clear/white on the inside, the outer is as you described, using an 1157 bulb. The inner was reverse lamps, using an 1156 bulb.
On an RS car, with a red lens all the way across and reverse lamps below the bumper, I believe both sockets on the taillight itself were the 1157 sockets, so both sides would light up for all three functions.
Hi,
There is NOT a 2nd set of sockets. There is an opening in the lens, but not socket or wires or anything. The backup lights are below the bumper. Any ideas?
Thanks,
Enrique
E -
My guess would be that it isn't an original RS car, and when they needed the wires to hook up the backups under the bumper, they just chopped and tossed the socket. That's the only reason I can think. It's easy enough to get a replacement tailight socket (three wire if you want stop/turn and parking, two wire if you only want parking) and splice it in. That's what I did on my 68 when I hooked the RS backups in. It might overtax the old existing wiring, but it didn't on mine.
The best way to do it correctly would be to get a 67 RS convertible rear body and lighting harness like the FactoryFit that American Autowire sells. It's just over $100 and it would get rid of any broken wires or splices in what you have. It could be a bit of a snowball project, because it runs from under the dash all the way back, so you have to remove the driver side kickpanel, door sill plates, wire gutter covers, top and bottom of the rear seat, and the rear arm rest panel on the driver side. But, you'd get it taken care of and not have to worry about splicing and shorts, etc. You'll probably spend $25 on parts and 3 hours or so to splice some sockets in, vs. $100 and 8 hours or so to do it "right."
Hi Eric,
That was quite informative. Thank you very much for the info. I'll probably buy the rear harness and do it "right".
Thank you so much,
Enrique
Thanks Eric, you basicly described what Camaro Model I have. That is it is base model. My tail light lences are Red, White, they are separate sockets. Thanks for being informative.
I have a question for you Eric. If you have old electrical wiring going to your tail lights. Would you replace them?
Jon -
It depends on the condition of the wiring, and your plans for the car.
As noted, the rear body harness is relatively inexpensive and easy to replace. Same goes for the front light and engine harnesses. An engine harness change is almost a must in my mind when going from an L6 to V8, and/or if you want a clean way to convert to an internally regulated alternator or HEI distirbutor.
The main dash harness is more expensive, and a lot more of a project as far as disassembly goes.
The quality of the reproduction harnesses such as those made by AAW is very good. Some like the peace of mind of new wiring in an almost 40 year old car. I did.
What does AAW stand for, like the web site where I can look at them?
http://www.americanautowire.com/
The OE style plug and go harnesses are under their Factory Fit line, and are sold by most of the major Camaro parts houses. You can call and ask them any questions you might have, but when it comes time to buy you can go wherever the best price is. AAW makes money either way, and their customer support is top-notch.
Theresa from AAW is a regular here.
1 - 12 of 12 Posts
