Here is my problem. Coming home from a car show toinight I start everything up and I have no taillights and no dash lights. The headlights work, the brake lights and turn signals work BUT no dash lights and no rear running lights. I got home check the fuse it is blown, change it and it blows again. I obviously have a short but cant find it.
I changed the rear drivers side light bezel this afternoon and I am sure that has something to do with it but I cant figure it out.
Any ideas, I need to fix this by Wednesday because I'm going to the track
you changed out the bezel which means you touched the wires. Open your trunk and check that one of the wires didnt' break
e loose and is grounding out at the light, or that one of the wires is pinched between the bezel and the rear panel and shorting your lights out. Just playing with the wires may remove the symptom, but you'll still need to eye the wires to see where the issue lies. Really shouldn't take but ten min max to fix the issue.
