Ok so I'm trying to fix my temp sensor on my 69. I have the factor console gauges in my car. From what I know about the history of the car I would believe it to be factory. The gauge never seems to work. However when I ground the wire at the sensor the needle on the gauge goes halfway between the C and the H. Never any further. This is the first issue.
Secondly I have aluminum intake with aluminum heads, and the sender is installed in the front of the manifold. Once I have the gauge working properly will this stop the sender from working correctly?
Thanks,
Jake
Thanks,
Jake
