Does anyone know how warm it needs to be to work with body filler? I am using Rage Extreme and it doesn't say anything in the directions about a working temperature range.
any temp above freezing is ok, but i personally like 60 degrees, everything flows and dries faster at a warmer temp.
Thanks Jason. The weather is finally getting better in northern Ohio but it will probably be another month before we regularly see 60 degrees or more. It may be two months before you see spring temperatures.
