I've been running a 2" drop base 14" open element air cleaner under a double pump holley. I'm now switching to Terminator and the drop base cleaner hits the TB. Anyone here run a Terminator? What open element base are you using?
Thanks.
Brett - Leander, Texas 1969 SS396
I'll be following this as I am going to need the same solution.
Brett....
Mine was just a regular K&N drop base. It’s been a couple years but I think I just clocked it 90* off from where it normally would be with a carb.
I installed the Holley Stealth Terminator on my 67 RS/SS. I used a half inch spacer between the throttle body and the air cleaner base. I am running an open element air filter my base is a repop similar to the one found on 302's. My 350 is older and has the crankcase breather behind the distributer. So I need the breather tube that sticks down from air cleaner base for crankcase ventilation. If you do install a spacer check air cleaner hood clearence
