I've searched and found that in order to install mt th400 in my 67/conv , I will need a new crossmember. My question is ,I used my polyurthane small block engine mounts. Will the TH400 still mount to the new cross member?
Banned
Yes, it should. It's just that various years and engines sat in the engine compartment a little differently due to different height and width motor mounts. pdq67
The turbo 400 is also longer than PG, turbo 350, 4spd, 3spd, which all are the same length, by 1/2 inch or so, which makes the need for the 400 crossmember, which sets the trans mount rearward to compensate for the extra length.
69 rallye green X77 Z/28,1967 SS 396 Conv. 1974 c-10 454 swb
UPDATE...Installed the new crossmember this weekend. Aside from drilling 2 new holes into the frame. It fit perfect, even with the smallblock motor mounts.
