Well, I had a post going about my 498BBC. After riding in a ls swap camaro I got the bug. It's a LS7 with a D1sc. Only running 8lb pulley with conservative timing. Motor was built by Billy Briggs at Motorcity Speed. Rich Gala at Motor City Speed handled the tune. Fab work was done by Motofab and Henn Racing. Anyways, here are the pics.
Posted some of these before but here is my starting point. This pic is straight from the original craigslist ad
Not too long after I went with modern size wheels and brakes.
Decided to change up the look with some carbon overlay parts
Before
After
Of course I couldn't leave it alone so had to powder coat the wheels. Figured that I might as well widen the rears so I would only have to powder once.....
That's were the trouble began. Not accounting for how much widening the wheels would affect rear fitment I had to gut the rear suspension......and that's where it began to spiral.....
Hey, might as well do recessed subframe connectors.
Modify front subframe. Sure, why not?
Hmmm might as well do a fab housing.
Discussion Starter #2
Old cage was hodge podged by myself so might as well...
Main hoop welds
Shock mounts
Decided to go with coil overs in the front to match the rear which in turn caused this. A-arms setup for factory suspension had to be modified.
Motor mounts had to be modified
New cross member
Tabs and clevices for easier removal of the trans.
Cross bar for the ladder bars
New motor requires more fuel so I went with an Aeromotive cell with integrated A1000
Sneak peak of the motor
Mock up but you get the idea.
At least the cookie cutter Kooks fit!
And here's a repeat of rough draft of the ride height
Upper shock mount modified, bolt in my ***....
Ladder bars and housing back from powder
Front clip
Mcleod RXT
Brake lines done
Swing outs bc it's a street car
Bracket made for clutch master resevoir.
Radiator mounted and breather for pcv plumbed
Fuel line are finished from rails to regulator. Just have to run the feed and return to the fuel cell
Exhaust is done. My goal was to be driving it last month but life happens. I'm very happy with how the exhaust turned out. Special thanks to Ernie Miyamoto at MOTOFAB for the exhaust.
Well, the car is just about wrapped up. Only running 8lbs with conservative timing left out but I'd rather be safe than sorry. The car weighs 3100ish so it is a handful. All that is left is finishing up the rear seats and headliner!!!!!
