1 - 2 of 2 Posts
I search and search....
I remember times when you guys talked a lot about doing an auto to manual swap. I remember one forum that mentioned a place that had all the materials and everthing you need for the swap. Pedals, housing...etc..
Any body remember where or what that place was!
Or where some of you guys found all of your parts needed for the auto to manual swap.
you will need quite a lot of pieces:
transmission
bellhousing
flywheel
throwout bearing
clutch/pressure plate
clutch fork
pedal assembly
clutch linkage (lots of small parts, can usually be bought in a kit from Ricks and others)
shifter
may need a different crossmember and driveshaft too.
I think that is a pretty complete list. Don't forget about all the hardware for each of those pieces too.
1 - 2 of 2 Posts
