guys,
ive got a rag joint from lees and a third gen iroc box. im trying to reuse the bolts from my manual steering box, but for some reason, the bolts seem to go through the subframe and enter the box "tabs" at an angle. what am i doing wrong here?
thanks guys
Discussion Starter · #3 ·
yeah, perfectly.... i dont get it. do i need a spacer or something or is my camaro a one off special subframe? :) this is a 67 with manual steering if it helps....
Discussion Starter · #4 ·
also, im trying to install it with the rag joing loosely on the PS box and just shoving the rag joint up to the steering column... i have not loosened the steering column. and, there is no engine in the car...
Discussion Starter · #6 ·
well, i have the first bolt on (the top one) no problem, but i just cant get those bottom ones started... ill try the column too...
Discussion Starter · #7 ·
wow, i just read how to remove the steering column... i dont have to disconnect everything do i? i was hoping id just have to loosen a few bolts to move the column up a little...
