1 - 8 of 8 Posts
This is the starter Butler sells. The one I have is no longer made. I just blew $220 because I scratched it good getting it around the headers to see if I could even make it work. I'm pretty sure I ruined the solenoid on the old one taking it apart to see if I could rebuild. Its not a design I have found parts for.
There is a mechanic a mile away. In a few weeks I'm going to ask him to figure it out.
That would be great if I had a Chevy motor. Really regret this car.
Does the Pontiac take a different starter than a BBC does? Isn't that a Powermaster starter? Starters is one thing I don't skimp on. I go Tilton Super . Easy to work on and always parts for these.
Don't give up yet .
I have a friend with 69 bird Protour with a Pontiac motor. He has spent a fortune on it and it is cool but will never match a Camaro in performance or value.
Seems to me you talked yourself into this deal and my personal opinion is to get out of it ASAP.
I may be an idiot:
The starter is "clockable". There are two bolt I can back out and rotate it to any mounting position I choose/need
I WILL be if it works. I'll try again over the next few days. The bracket still looks too small.
I bought it because it was different, cheap(20k in drivetrain alone on a 25k priced car, with mostly "new" metal). And sorted out.
I have to take it to a trans shop to get all new seals on the speedometer gear housing. I simply can't get it off. No leverage/good angle with the exhaust in the way.
I may be an idiot:
The starter on the right is infinitely clockable. You can spin it all the way around or just a fraction of a degree. You should be able to get it to work. :beers:
I bought a mini from Classic Industries and took it back as it would drain my battery after cranking it for 4-5 seconds....double checked the battery and it was fine. Put my old starter back with a heat shield no problems so far....
1 - 8 of 8 Posts
