1 - 1 of 1 Posts
I just installed the GMP-14 coilovers and had some questions. With the coilovers installed and the suspension hanging free the shock is extended all the way and I still have almost 1/4" of travel left before the upper A arm will come down on the bump stop. Is this normal? The springs are adjusted all the way down for now. Also, I'm running Speed Tech upper and lower control arms. The progressive spring rate is 250/350. Is anyone else running this rate and how does it handle? Too soft? Thanks
1 - 1 of 1 Posts
