I am just installing my M21 on a DZ302 and have a question about the position of the throw out bearing on the clutch fork. I understand the function of the spring type claps inside the clutch fork as far as holding the throw out bearing while mounting the transmission. What I am not sure of is are the springs supposed to hold the throw out bearing in the same position, secured under the clips all the way until the transmission is bolted back up to the bell housing? It felt like the bearing came off of the slips as I slid the transmission into place. Understand that I am installing the transmission back on the motor by myself while it is in the car so those of you that have done this before can agree it is not too easy to tell exactly what is going on.
Thanks as always for your help. Team Camaro Rocks!
