1 - 2 of 2 Posts
I want to put a tic toc tach in my 68, but in the add for the tach it said not to use with a hei dist. Is there some way to hook this up. Thanks Ernie
I have an aftermarket Tic Toc Tach on my car with HEI. No problems. The way I remember it, you have to order the correct wiring harness so it plugs into the HEI "port".
Here's the note from the Factory Fit website who I got my wiring harness from:
PLEASE NOTE:
All stock harnesses can be modified to incorporate HEI or alternator modifications even if not listed. Please place a comment in the "Notes" section of our webstore order form stating which modification you need for your vehicle.
Tach works fine...
You can use a tach filer if need be. I didnt' need one. Bought my tach from Classic - made by OER.
http://www.camaros.net/forums/showthread.php?t=173302
1 - 2 of 2 Posts
