1 - 20 of 42 Posts
Discussion Starter · #6 ·
I have an update with pictures on the floor pan inst. I want to make sure I don't miss anything, it starts on page 6, anyway the bride :) says to go to whats new.
Rob
Discussion Starter · #8 ·
Had a question on another forum about the rocker flange and tieing the back of the pan to the floor, so another update, you guys know where to find it.
Rob
Discussion Starter · #12 · (Edited)
The picture doesn't show the center of the pans very good, (driveshaft tunnel), anyway I pulled out ten screws the full length of it, then as I kept putting the screws in it just naturally over lapped the other one, and the center seam is tight, didn't have to put a screw in between the supports, I got lucky, I was wondering what was going to happen when it came together.
Rob
Discussion Starter · #16 ·
Ahowudoin, good question, our local body supply ( browns ) in two rivers has it in stock, I looked at it, and I think the cost of it got me.
Then the way my body jig is set up, I decided against it, worried about losing the shape of the body, removing all the supports at once.
If I was a better body man I would have went for it.
If a person knows whats he's doing, the full floor would be the way to go.
Good question, and I know what you're saying.
Another reason is I work alone, and getting that thing in, looks like a two man job.
When you work alone, you don't have anybody right there for a second opinion, and thats my fault, I'm to picky.:)
Rob
1 - 20 of 42 Posts
