1 - 20 of 24 Posts
I am looking for a tilt column and need to know what years & models of cars I can transplant one from? I am wanting it for my 69 RS. I have installed a set of Fiero buckets and need the extra flexabiltity.
69 RS Camaro (383,700r-4,12-bolt w/3.73s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4,140k miles)
97 Bonneville SSE 40th Anniv. (3800 V-6, Power Everything, The little woman's car)
Check out my site and the For Sale Page http://rodsrides.freeservers.com
The tilt in my 69 Firebird is out of a 69 Gran Prix. Almost any pre 70 tilt will bolt up but some are a couple of inches too long. If you can weld, you can make them fit. Cut the tube and inner shaft down by where it goes thru the firewall. You can make a 69 fit a 68 and down by removing the key assemble and filling the hole.
Discussion Starter · #5 ·
Mark C, so you say that there is no direct bolt in? Is there a difference in length or what? Has anybody done the Monte Carlo?
PitStop, did you put that in your self?
I have a 70 Nova SS and I used a Camaro tilt wheel column and it bolted right in. I bought the column from D&R classic Camaro out of Chicago a couple of years ago. It's a stick shift column that was rebuilt. It only cost me $200 then but they're close to $400 now. Hope this helps.
Paul
Hey, I've been thinking about converting to tilt for a while, but just wondering, most of the donor tilts have the ignition switch in them, is it difficult to remove this switch/cylinder? and after you remove it, will the steering still lock?
Also what about 1970-81 Camaro/Firebird columns are they interchangable? I know that some chevy vans had tilts with no ignition switch in the early 70s, anyone ever try one of these?
thanks
For what it's worth....
There was an orange 68 featured in a lot of the mags over the last year or so that was stated as having a tilt column from a 1980 Chevy van. No other particulars were given as far as mods were concerned though.
Bret Copsey
'68 Camaro base coupe
'92 Caprice Wagon
'99 Venture Van
my 68 camaro
To wildcatz and team canada
I've done a couple of tilt columns, 2 for myself and a couple for friends. Any older GM tilt column can be made to fit a Camaro. It won't be "CORRECT" but it will work and on most you would have to look real close to tell the difference.
The top part of the column where it bolts under the dash is the same. The difference is the overall length. I has been a couple of years but if I remember correctly, the full size cars are about 4 inches too long. As I said before, you can cut and weld them at the fire wall end and it won't be seen because of the boot on the floorboard.
The're 3 shafts that have to be shorten.The outter housing that you see. The inner tube which is used as the column shifter or reverse lockout on a 69. The inner shaft which actually steers the car. The only one that is critical is the inner most shaft. It is two pieces that slide and are held together with a plastic filler. Suppose to collaspe in case of an accident. Weld as far away from the plastic as you can, so as not to melt it, and if you are not an really good welder, pay somebody to do it,because this does steer the car.
As far as using a 69 column in a 67 or 68, and you want the key gone. Take the upper housing that holds the key assembly and grind of the part that sticks out that holds the key. Be careful to keep the shape round. Clean up the hole good like you were going to paint it and fll it it with JB WELD. Fill and sand till it is perfectly round and paint it to match.
My 68 has a 69 filled column and it has held up for 6 years now. The streering wheel will not lock if you do this. The key assembly has a gear on the the end which moves the rod that locks the wheel.
Anymore questions let me know.
I had to have a tilt because of the big lump that grew above my belt after I turned fifty.
Bill
Check out Flaming River for an all parts new column. They are about $300. The problem I found was their 69 column did not have the provision for a key.
69 Camaro Z28 "clone" - 327 AT
"461" camel back heads,
edelbrock , hooker, ultradyne cam, stewart,
TRW etc.
Vintage Air (not yet installed)
700R4 TPI transmission
Watch ebay. Going rate is about 250, but occasionally they go for much less--especially column shift. you could grind and fill the bowl as for the key, above, or look for a junkyard column that you could pirate the bowl off of.
I'm going to add a little to my previous post. I have never payed more than $25 for a tilt column. You can buy column shift tilts out of older GM cars cheap, one because they are more common especially in Buicks and Pontiacs, two most Camaros have a console floor shift and people don't want a useless shift lever hanging of the column.
If it is a 69 column shift tilt column,and it is going in a 69, all you have to do is remove the shifter, grind down the bowl where the shift lever went in, and fill with JB WELD. All of the 69 featues will still work, wheel will lock and linkage from the trans will still work the reverse lockout. Remove the shift indicator, buy the correct turn signal and tilt lever and flasher knob, once painted no one would ever know.
If it is going in a 68, remove the key as I explained earlier, Then 69 featues such as lockout will not work, but 68 didn't have those features anyway.
GM used the same turn signal switch and neutral safty switch so electrics are not a problem.
You can do a little work or spend 300 dollars, both ways work.
Bill
Team Canada
If I was going to the bone yard for a tilt, if you can find one that still has pre 70's cars, look at 4 door Buicks, Pontiacs,Olds not so much Chevy. These were the more expensive cars and more likly to have options.
Thing to remember that in the 70's there was a lot of difference in GM models but GM engineers tried to made as many parts as they could fit as many different models as they could. To save costs I guess. I remember in the 70's that a Olds or Buick part costs twice as much as the same part for A chevy.
Look at your non tilt column closely, and when you get there, you'll be surprised when you see the same thing in other models.
Bill
Discussion Starter · #18 ·
Thanks Pitstop
Discussion Starter · #20 ·
If somebody that has a tilt column in there's wouldn't mind, would you please measure it for me. And please let me know the 2 points you measure from. I really appreciate it and would like to see if everybody's measure the same or if a couple of inches longer or shorter is that noticable.
1 - 20 of 24 Posts
