Got the following items taking up needed space, email me for pics and details:
68 rear axle, complete drum to drum, 3.08 open mono perches, good except for a broken pinion yoke.
68 front drum brakes, complete, no spindles or steering arms.
73 Nova rear drum brakes, complete, will fit Camaro.
68 original a-arms, with good poly bushings and good lower ball joints.
68 original 28 spline axles
68 327-275 rotating assembly, crank rods, std size pistons, 1 piston probably bad, had broken compression rings
hello JimM,
first off sorry about the 10 bolt open rear end and not getting it from you.
my suburban is acting like a piece of crap lately and i just didn't want
to kept bugging you about the rear end through e-mails and phone calls.
also what are you asking for the 4 control arms you have and what
brand are the polyurethane bushings.
my upper control arms look good and i see rust on the bottom ones.
im getting ready to put my disc brake set up on the car so i might buy
your control arms to be on the safe side.(within the next 2 months)
thanks for your time and sorry once again about the rear end
mark b
hey jim,
thanks anyway and i might just get new control arms
because i have new ball joints and poly bushing also
mark b
