1 - 14 of 14 Posts
I am looking to replace the tires on my 1967RS which are currently 215/70-14 and are on Centerline rims. I was looking to replace with a 225/70-14 and concerned that there might be tire rub issue. I just installed Moog 6308 springs and new shocks to help eliminate any problems. I would like to hear from anyone that have the 225's and any problems and suggestions.
I just ordered some 225/70/15's to take place of my 215/70/15 on the front with a 7" wheel and 4.25" BS. I'm running 235/70/15's on the back with an 8" wheel and 4.5" BS. I don't anticipate any rubbing. I also just installed Moog 6308's as well, which raised the front end an inch.
Not sure what the offset is,they have been on the car since the late 80's. Is there way to figure out the offset.
Just remove the wheel and see if there are some numbers printed on the back side of the rim. If not, place the wheel face down, lay a flat edge across the wheel (not the tire, just the rim itself), and measure from the flat edge to the wheel hub and that will give you your backspacing.
Discussion Starter #8
Checked the offset as suggested and it measured 3-1/2" would there be any problem with tire rub. Also found a set of Cooper Cobra's at a reasonably internet price, does anyone have any information on these tires.
I am wondering the same thing. I currently have 235- 60R/14s on my 67 RS. I have rubbing on my frame.
I wanted to go to a 70 series tire to fill out the wheel well a little better. The best size for this is 2250 70/14s.
Am running a deep dish 7" wheel, not sure my offset, but I got the least I could last time I bought tires- to clear the tie rod ends. Before I went with the deep dish wheels, the tie rod ends were running into the sidewalls.
JHaynes, would love to hear how it works out.
Are those 7" rims? 6", 8"? You need to know the width of the rim, the back spacing (offset) of the rim, and the tire size. If you don't know all three, you are just guessing.
With that said, with 3.5" back spacing you will have plenty of clearance on the subframe with any of those widths, it's just a matter of fender clearance.
If a 235/60/14 rubs on the inside, a 225/70/14 should be worse. Even though it's narrower, it's a fair amount taller and will hit the frame sooner.
Time for new wheels or spacers.
Discussion Starter #13
Is anyone running the 225/r70-14 and if so what problems are you having? Any suggestions on the best tire size for the 14" rims?
I am running 225-70-14 on a stock 14" rally wheel and stock springs. The tires rub and they look too tall for the 69. My other 69 has 235-60 on 15 vette wheels and works fine. I would check out 235-60-14. . . .you can go to tire rack and get the demensions on all the sizes
1 - 14 of 14 Posts
