Have any of you guys had any problems with Goodyear Eagle F1 All Season tires in size 275/40/ZR/17 not holding air specifically leaking air from between the tire wall and wheel rim? Two tires on my 2002 Camaro SS lose between 5-7 pounds in less than a month and the other two lose 15-17 and 21-23 in the same amount of time. I have found on 1 tire, the one that loses the most air, a leak right between the tire wall and where it contacts the wheel rim. This was based on soap bubbles coming from this area after spraying the tire with a water/soap mixture. I've never had any tires on any of my vehicles ever lose this much air in so short a time. Thanks.
