Hello,
I have about 1000 miles on my TKO now, and instead of getting smoother, it has actually gotten worse in shift quality.
I'm using mech clutch linkage, Mcleod 12" clutch assy, Centerforce flywheel, Mcleod scatter shield, Mcleod Slik stick shifter and is filled with GM synchromesh lube.
It's always been clunky and occasionally required a push to get into any gear, but is worse when going from Nuetral into any gear from a stop and shifting has felt very Muncie-like. But these last couple times out, when downshifting 5th to 4th it grinds going into 4th.
I did try readjusting my clutch rod, but it did not help.
The clutch starts to grab about 1" off the floor.
I've never dumped the clutch but have floored it in each gear several times, and done a few runs while speed shifting.
What do I need to look at?
Do I need to pull it and take it in for some warranty work?
Tim
Tim
