41 - 60 of 168 Posts
Discussion Starter #41
Took her out around the block today...Her first drive in years...
Discussion Starter #44
That is not the correct way to apply filler. You should pull it lengthwise and spread it smoothly beyond the repair area with long strokes. Don't apply it vertically. Shortstrand should be used first, followed by an easy to sand filler like Rage Ultra, $38 per gallon, sands very easily.
Tony great work car is looking good......90 days something to be proud of......
Some times help from fellow members in text does not read as it was intended.......
X2 on Scott's suggestions for the filler and its application......one of the best ways to look at your filler work is to use a 4ft florescence light when in primer during the wet sanding.......bends in the reflection means there is still some work to do......and will show in the final paint work......we all can get a little snow blind and miss small waves and such.......
keep up the good work.....and the pics coming.....
8Ball
Discussion Starter #48
Awesome! Thanks..
Discussion Starter #49
8Ball
Thanks Matt!
Discussion Starter #51
Had warp in roof to repair
I removed the old patch and the warp went away. I annealed the new patch, gave it a slight curve and then tacked it in using planishing techniques given by forum members. I followed body filler advice by Scott and other forum members to finish quarters and roof...
I'm finishing up the filler around the windshield today and tomorrow...
Took her out around the block today...Her first drive in years... :thumbsup:
I am jealous. Maybe someday my car will roll under its own power.
Discussion Starter #55
I'm holding you to that Patrick!
Love the work m8, looking really good! I'm curious to know why you filled between the rear quarter and sill? Is it meant to be like that as I think mine had some sort of seam sealer there. Not complaining though as I quite like the look and would be tempted to do it on mine! I would worry about it flexing and cracking though?
Discussion Starter #58
I thought it would look better this way. Hopefully the area should not see much movement...
Unless it was fully welded and reinforced, it will crack. Not to mention water enters from the backside. The lower radius you introduced may not work with the door's 90° corner and might be a clearance issue. It will also look odd being mismatched. Any vertex is prone to cracking, look at any failure in a car's sheetmental or aircraft design.
I lost track of how many cars I've had to repair where people slathered filler over seams.
Discussion Starter #60
Hope fully it won't crack...I used filler over short strand...
