A buddy of mine is trying to diagnose a top end knock. It started after a high RPM freeway run. He 'says' he never spun past 5500, but he has no rev limiter and was shifting the car with a column shifter :noway:
The motor is a 350 - 488/510 lift cam, Edel RPM heads, roller rockers, and timing gears. He said after the valves were set again after the high RPM run it quieted it down at idle. He sent me a sound/video clip and at aroung 2500 rpm or so it has a knock (not a tick or clatter - a knock) and it is definitely on the top of the motor. I initially told him to check the push rods - glass roll them, and check the valve springs.
Is there anything else, other than a lifter (hydraulic) that any of you can think of?
Thanks in advance for any thoughts.
