1 - 2 of 2 Posts
i'm looking for anyone who has information on a torque specifications on a 1968 camaro rear differrential 10 bolt non posi. i need the torque specifications for the two caps that hold the differrrential in the pumpkin, and also the torque specification for the yolk, same car. thanks michel
:confused:
The carrier bearing cap bolts get 55 lb-ft. The pinion flange nut torque depends on what it was when you took it apart, and whether you measured the pinion bearing preload. Free-running pinion bearing preload (no ring gear installed) should be 20-30 inch-pounds with new pinion bearings, or 5-15 with used bearings.
1 - 2 of 2 Posts
